Web UI bug: Displaying HTML on page
Found this on the Setting page (Safari):
CleanShot 2022-12-28 at 11.27.11
Notice how the HTML for creating a link is being displayed, rather than providing a clickable link for “similar homes”. This is happening because the actual code uses &lt; and &gt; instead of < and > in the page code.
This is, no doubt, the result of a piece of code that is sanitizing text from a file or database, before being inserted in a page. This is, generally, a good security measure, but clearly accommodations need to be made where HTML is intended to get through, or, even better, a special kind of format should be allowed in the stored text that, upon transformation and filtering will produce valid HTML for the link, but still strip unwanted HTML.
Hi Dolf,
I have identified this bug and reported it. I will let you know when I can confirm it has been resolved.
Thanks again for your help!
Hi @dolfs
I can confirm that this issue should be resolved.
Check if you would like on your end and let me know! Thanks again for all your help!
CC: @JuliaAtSense @kevin1
