You just installed your Sense and you are raring to see it start detecting devices in your house. The first question that many users ask while waiting for that first detection is “How do I convince myself that the Sense numbers are accurate (or figure out that you have a cheating utility company) ?” This is a short primer on ways to double check the basic numbers coming out of your Sense.
What can you do ?
Just believe - Lots of other people have validated Sense’s accuracy in their particular installs via a variety of methods. There are plenty of examples on this forum.
Immediate spot check against your meter - This works well if you have a relatively constant load in your house at the time, which would mean that your Total Usage in the upper right corner of the Power Meter is fairly stable (and the same for Solar Production in the upper left corner if you have a Sense solar install). You can do this the second Sense is done calibrating after setup… One nice example on how to do this with a standard electric meter from @jkish here. I’ll share the same for how to do the spot if you have solar and a net-meter as well, in a little bit.
If you can wait a little, like a month or so, you can check against your first full utility bill. If you are lucky, your bill / meter readings are on the same day every month, or even better, at the end of the last day of every month. That allows you to use the Sense built-in trend intervals. If not, you can still approximate by doing a little calculator work and summing individual daily usage together from the Sense daily Trends data. An example on how to do this will follow.
Do a detailed analysis - If you can’t do any of the above, or if you try one of the above and the two measurements aren’t correlating, then you’ll need to do a more detailed investigation. Fortunately, Sense, plus most utilities give you the tools to do a deeper analysis and figure out where any differences might be coming from. I’ll spend a couple of posts on how to do this kind of analysis with Sense exported data and a spreadsheet or R.
More details on these different methods in the next few posts.
